FTDI USB To Serial Adapter
Sold By Earth People TechnologyThis product is no longer available for sale.
$56.99
$13.99
$6.99
This Gold Plated Fast FTDI based USB 2.0 to Serial Adapter provides an external plug & play RS232 serial connection with your computer via the USB port. Users have the capabilty to utilise the US…
Read More…This Gold Plated Fast FTDI based USB 2.0 to Serial Adapter provides an external plug & play RS232 serial connection with your computer via the USB port.
Users have the capabilty to utilise the USB to RS232 adapter with serial port interface in an easy-to-use environment.
This adapter has been tested with many different items of test & measurment equipment and has been found to work well. Uses the highly regarded FTDI CHIPSET
We have some RS232 equipment that will only work with the FTDI CHIPSET.
Please note the total cable length is 30 cm end to end (connector to connector).
This FTDI USB to Serial Adapter is designed for connections to GPS Systems, Monitoring Equippment, PDAs, Digital Cameras, Modems, Data Aquisition Boards, ISDN Terminal Adapters and software that uses Serial Ports.
Just simply connect a serial device to the USB2.0 to RS232 adapter and plug the USB port into the computer. Supports automatic handshake mode. The cable length is 30cm from end to end Supports remote wake-up and power management for upstream and downstream data flow.
Installed as a standard Windows COM port Full RS232 modem control signals RS-232 data signals; TxD, RxD, RTS, CTS, DSR, DTR, DCD, RI, GND Frees your RS232 port for other uses No IRQs required, no IRQ conflicts Easy Installation and the FTDI USB2.0 to RS232 Adapter supports the following Operating Systems.
Windows 8
Windows 8.1
Windows Server 2008 R2
Windows 7
Windows 7 x64
Windows Server 2008
Windows Server 2008 x64
Windows Vista
Windows Vista x64
Windows Server 2003
Windows Server 2003 x64
Windows XP
Windows XP x64
Windows 2000
Windows ME
Windows 98
Linux
Mac OS X
Mac OS 9
Mac OS 8
Windows CE.NET (Version 4.2 and greater)
4 Reviews | 319 Orders
$56.99
$13.99
$6.99
$6.99
$27.99
$6.99
