A Teensy-sized simple breakout board for STM32L052C8T6 and STM32F072C8T6
Designed by 42_red_herrings in United KingdomNo shipping info available.
PLEASE NOTE: I am out of these, and no longer make them. Thank you for looking, and please accept my apologies. The bat board is a pretty minimal Teensy-sized breakout board, offered here assembled w…
Read More…PLEASE NOTE: I am out of these, and no longer make them. Thank you for looking, and please accept my apologies.
The bat board is a pretty minimal Teensy-sized breakout board, offered here assembled with STM32L052 (32MHz max, 64 kB flash, 8kB RAM) or STM32F072 (48MHz max, 64kB flash, 16kB RAM).
Because of the power options, this board is quite suitable for very low power applications, e.g. a battery powered sensor (especially with L052), or USB applications (especially with F072 because of the built-in DFU bootloader).
I have run out of some of the components, so the current batch (compared to the previous one) comes with STM32F072C8T6 (i.e. 64kB flash now instead of 128kB before); and the L052 boards have white, a little larger pushbuttons instead of the very small black ones like (still) on F072.
Well, the firmware is up to you (although I have a few examples using libopencm3 on my repo here; and there are a few precompiled test firmwares available on the documentation page). That page also has some more detail about uploading a firmware to the board.
A brief summary: when holding the "PA1" button during a reset or powerup, the MCU enters the built-in bootloader. The F072 has a DFU bootloader built-in, so no external hardware is needed to flash this one, only some software, e.g. dfu-util. The L052 only has a USART bootloader built-in, so an USB-to-Serial board is needed to use this. However I modified the BMP bootloader to act as a DFU bootloader on the L052 as well, and these L052 boards ship with this programmed in. So also the L052 boards don't need external hardware to program them (note that this one is entered by connecting PB3 and GND during reset/power-up, and the firmware needs to start at 0x8002000 instead of the usual 0x8000000, i.e. the bootloader takes up 8kB of the flash).
The SWD debug pins (SWDIO, SWCLK), along with power, are broken out along the short side opposite the USB, so they are easily accessible. So, if you have a SWD debugger ready (e.g. STlink V2, or jLink, or BMP, or a clone of these), you can flash the board this way.
The STM32L052 chip is also used in Jeenode Zero. So these can (and do!) run forth. The mecrisp stellaris runs on both variants (L052 and F072). I have also modified Jean-Claude Wippler's serial-over-USB driver for mecrisp to run on F072, so that you can run forth prompt 'natively' over USB on F072: sources and a directly-flashable binary firmware here.
The PCB itself can take any pinout-compatible STM32 MCU (in LQFP-48 package). I've tested it also with the ubiquitous STM32F103C8T6. The optional high-speed external crystal and pull-up resistor on D+ are primarily there to support chips like this, which require a crystal for USB.
If you'd like to build the board yourself, you can get the PCBs from OSH Park or pcbs.io. These are rev3, which is needed for non-Cortex M0 MCUs. i.e. no difference for the MCUs offered here. The only difference between rev2 and rev3 is that BOOT1 pin is tied to GND in rev3, which enables the built-in bootloader to be entered with the "PA1" button also on M3/M4. It's probably cheaper this way than from me because UK shipping is rather expensive.
If you'd like one of these with a different MCU than F072/L052 offered here; or have some modification done before I send the board, get in touch!
I have one extra rev1 populated PCB with F072, offered at a discount. Rev1 has a different pinout (can be seen here) and does not have the footprint for the pull-up on D+ (this is not needed for USB on F072 anyway), and does not have the solder jumper to disconnect PA1 from the BOOT0 pin/button. The PCB is 1.6mm thick, purple (from OSH Park).
Note These boards are build by me pretty much by hand, so there may by tiny soldering imperfections. However, the boards are fully functional!
Enter your email address if you'd like to be notified when STM32 L052 or F072 breakout: the bat board can be shipped to you:
Daniel | Oct. 8, 2020
Chandler's Ford, Hampshire, United Kingdom
Ships from United Kingdom.
4 Reviews | 38 Orders
$38.00
$23.00
$21.95
$14.99
