A SMT KIT for a small USB stick with ATxmega (128A4U), microSD socket and a RGB LED
Designed by 42_red_herrings in United KingdomThis product is no longer available for sale.
I do not plan on running any more batches of this board. The design is open (see links below), and you can buy the remaining PCBs that I still have here. Thank you for your interest! What is it? It's…
Read More…I do not plan on running any more batches of this board. The design is open (see links below), and you can buy the remaining PCBs that I still have here. Thank you for your interest!
It's a SMT kit for a small programmable USB stick (ATMEL's xmega chip), which can be used as an encrypted microSD storage, or as a Rubber Ducky (i.e. emulate a keyboard and/or mouse and emit a sequence of keypresses/mouse movements), or a mood light.
If you don't want to go into SMT soldering, already soldered (by me), ready-to-use sticks are available as well (it might take a few days though).
Some notes about soldering the stick can be found the in the documentation --->
It is designed to be hand-soldered (I soldered it with just a regular soldering iron and liquid flux :) The smallest parts are 0805, and the xmega comes in TQFP-44 package with 0.8mm pitch.
The above mentioned firmware are in development. You're welcome to fork/contribute. Current status:
Of course, to get the most fun out of this stick, you should write some firmware yourself! The chip is supported by avr-gcc (windowed people can use WinAVR) and Dean Camera's incredible LUFA library for USB functions. Alternatively, you can use ATMEL studio on windows.
The ATxmega comes with ATMEL's DFU bootloader preprogrammed, and it is triggered by pressing the general purpose button during startup (power up or reset). So after it's soldered, you can just plug it into the computer and program it, no external programmer needed.
The through-hole pads with standard spacing make it easy to extend the functionality on a breadboard, or with a "shield".
I wanted an USB stick that has a microSD socket and a chip which is easily programmable using avr-gcc and has a native USB capability, so that I can use it as open source/hardware encrypted usb stick. I decided to use ATxmega (as opposed to atmega32u4 or similar), since it's cheaper, accessing a microSD card is much faster, and it has hardware AES-128 encryption. And programming it is not that different from the popular atmega series / Arduino.
The kit comes with all the electronic parts needed to make the stick. You'll need your own soldering iron, solder and flux.
Chandler's Ford, Hampshire, United Kingdom
Ships from United Kingdom.
4 Reviews | 38 Orders
$28.49 $29.99
$119.00
