A read only ProDOS compatible bootable drive that can hold 1024 KB of data, fast!
Sold By HAL's friendsThis seller is taking a break. Sign up below to get an email when they're back!
A read only ProDOS compatible bootable drive that can hold 1024 KB of data that start in just a couple of seconds! The ProDOS ROM card is preprogrammed with ProDOS, serial/audio/Ethernet ADTPro clien…
Read More…A read only ProDOS compatible bootable drive that can hold 1024 KB of data that start in just a couple of seconds! The ProDOS ROM card is preprogrammed with ProDOS, serial/audio/Ethernet ADTPro client and an example selection of games and utilities. It's read-only: to change the content you need an Eprom programmer and the freeware utility CiderPress to create your own ROM.
This expansion card may be used in any of the Apple II expansion slot and will be the first to boot regardless of any disk controller present. To boot from a normal disk controller, please select BASIC.SYSTEM to exit to ProDOS and type PR#6 to boot from that device as per normal.
Please make sure the Apple is powered off when adding or removing the ProDOS ROM card. Take note of the correct orientation of the card (ROM towards keyboard).
Every unit is tested, before shipping, on an Apple ][e.
ProDOS ROM Drive design and firmware by Terence J. Boldt
Enter your email address if you'd like to be notified when Apple II ProDOS bootable 1MB read-only drive v4.0 can be shipped to you:
Seth | Aug. 7, 2024
$22.99
