This seller is taking a break. Sign up below to get an email when they're back!
What is it? The purpose of this project is to provide I/O for an Apple II series 8 bit computer via a Raspberry Pi which is powered by the Apple II expansion bus. This includes using the attached RP…
Read More…The purpose of this project is to provide I/O for an Apple II series 8 bit computer via a Raspberry Pi which is powered by the Apple II expansion bus. This includes using the attached RPi for it's storage, network and processor to provide new functionality for the Apple II.
The card enables the Apple II to boot from and write to virtual hard drive images stored on the RPi in any slot (except slot 3), execute Linux commands from Applesoft BASIC and run a bash shell with VT100 emulation. The code has very few tests and is incomplete. Note that currently the firmware assumes an 80 column card is in slot 3 and than you have lowercase support. Most development has been done with an enhanced Apple //e with the card in slot 7. If you have other drive controllers earlier in the boot cycle, you can still boot from the Apple2-IO-RPi. For example, if the card was in slot 4, you could type PR#4 from the BASIC prompt to boot the card. Note that the Raspberry Pi Zero W (and W 2) consume 170 - 250 mA and there is only 500 mA available to all expansion slots according to Apple.
A very promising card that is really useful if you you want a virtual storage to work with from an Apple II. To use it you need a Raspberry Pi Zero W (or a 3B, the one i'm using) and a SD card. Both of them are not included.
All the instructions to create the Rpi image and to use it are on the Terence J. Boldt (who designed it!, thanks Terence for this wonderful product) github page: https://github.com/tjboldt/Apple2-IO-RPi
Enter your email address if you'd like to be notified when Apple2-IO-RPi - expansion card using a RaspberryPI can be shipped to you:
Seth | Aug. 7, 2024
$59.98
$68.00
