The ‘Simple’ Wifi Modem v2 is a device that connects a computer with an RS232 serial port to internet
Designed by HAL's friends in ItalyThis seller is taking a break. Sign up below to get an email when they're back!
The ‘Simple’ Wifi Modem v2 -BLACK EDITION- is a device that connects a computer with an RS232 serial port to a telnet BBS. It does not use an analog phone line but the internet through a wifi connect…
Read More…The ‘Simple’ Wifi Modem v2 -BLACK EDITION- is a device that connects a computer with an RS232 serial port to a telnet BBS. It does not use an analog phone line but the internet through a wifi connection. It behaves like a Hayes dial-up modem, and it is designed and built for old computers; I use it with my first computer ever (still working!): a Sinclair Zx Spectrum and, being myself a retro-collector, also with a lot of other different machines.
My idea was to create a device with the same look and feel like a real modem: a lot of big, flashing, red LEDs, and only a few SMD components.
In this latest revision i have rotated the usb connector on the back (as requested!) and finally added an option for a 3d printed case.
Main characteristics:
Emulation of a Hayes modem
DB25 or DB9 serial connector
Uses 5v micro USB cable port for power (optional USB cable)
LEDs for status, as in old modems
Hardware flow control
Since revision 2 hardware flow control is fully implemented. The BLACK EDITION is a special batch to honor all the black computers (starting from the Sinclair Spectrum!)
Its design is open source and you can find all the schematics and full instructions in the Source Code link below.
The software installed is a fork of Zimodem written by Bo Zimmerman.
It has just been modified to support this device.
Enter your email address if you'd like to be notified when Simple Wifi RS232 Modem v2 can be shipped to you:
Product: (4.80)
Documentation: (4.20)
Communication: (4.40)
Jean-Yves | Nov. 2, 2024
Jerome | Sept. 5, 2023
Walter | Dec. 11, 2022
Niels | May 26, 2021
Philippe | Jan. 8, 2021
$37.99
$79.00
$35.99
$19.95
