Pi Pan by AVIES Tech - Raspberry Pi Model B Case w/ Mounting Option
Designed by AVIES_Tech in United States of America
Pi Pan is our aluminum Raspberry Pi Model B case with a black powder coat finish. It uses a universal base with interchangeable lids (coming soon). You can view some of the manufacturing process on …
Read More…Pi Pan is our aluminum Raspberry Pi Model B case with a black powder coat finish. It uses a universal base with interchangeable lids (coming soon).
You can view some of the manufacturing process on our Kickstarter project: Pi Pan - A Raspberry Pi Case with Options (see documentation link)
Copy and paste the link below to read a user review of Pi Pan:
http://www.raspians.com/a-case-review-aviestech/
This case comes with the standard lid, which encases your Pi and has holes drilled to view the LED status lights.
With the standard lid you have access to:
-Audio and Video Outputs
-SD Card
-Micro USB Power
-GPIO
-USB
-LAN Connections
-Slotted RCA Connection
All case bottoms have six flush PEM nuts installed as a standard feature. Four on the sides which attach the lid and mounting ears. Two on the bottom for various sized flat panel mounting brackets.
Comes assembled with rubber feet
Made in U.S.A.
Enter your email address if you'd like to be notified when Pi Pan by AVIES Tech: Raspberry Pi Model B Case can be shipped to you:
