Semtech LORATM SX1276 SX1278 long range wireless transceiver module
Designed by DORJI in China
Features: Frequency Range: 433MHz Modulation: FSK/GFSK/MSK/LoRa SPI Data Interface Sensitivity: -138dBm Output Power: +20dBm Data Rate: <300 kbps 127dB dynamic Range RSSI Excellent blocking immunity …
Read More…Features:
SPI Data Interface
Preamble detection
Automatic RF sense and CAD monitor
Built-in bit synchronizer for clock recovery
Packet engine up to 256 bytes with CRC
Working Temperature: -40°C ~+80°C
Build-in temperature sensor
Standby current: ≤ 1uA
Supply voltage: 1.8~3.6V
DRF1278F is a type of low cost RF front-end transceiver module based on SX1278 from Semtech Corporation. It keeps the advantages of RFIC SX1278 but simplifies the circuit design. The high sensitivity (-136dBm) in LoRa modulation and 20dBm high power output make the module suitable for low range and low data rate applications.
DRF1278F module consists of RFIC SX1278, thin SMD crystal and antenna matching circuit. The antenna port is well matched to standard 50 Ohm impedance. Users don’t need to spend time in RF circuit design and choose suitable antennas for different applications. DRF1278F operates at 1.8~3.6V with extra low standby current which makes it suitable for battery powered-up applications.
Because DRF1278F is purely hardware module and it adopts ±10ppm crystal which the resolution of it places a important role in calculating spreading factor, bandwidth, etc. Users need to read the datasheet of SX1278 carefully in order to use the module in the best performance. DORJI also provides sample codes based on microcontroller and Arduino platform. The customers who buy the modules can contact the sales of DORJI for modifiable copies.
Applications: Wireless Gas/electric meter, wireless sensor network, Automatic data logger, Industrial telemetry, Home automation, Remote keyless entry, Robotics control.
Notes: The price includes 1pcs of DRF1278F module.
Enter your email address if you'd like to be notified when Arduino 433Mhz Lora SX1278 Module DRF1278F can be shipped to you:
1-9 | $3.68 |
10-19 | $3.58 |
20+ | $3.48 |
Product: (4.67)
Documentation: (4.00)
Shipping: (4.33)
Communication: (4.17)
Kevin | Feb. 16, 2021
Murad | Nov. 13, 2019
J.F. | Nov. 10, 2017
Jithin | May 15, 2017
Michael | Dec. 18, 2016
Aidan | May 22, 2015
$8.98 $9.98
$8.08 $8.98
$7.45 $8.28
$12.60 $14.00
$3.85 $4.28
$7.18 $7.98
$23.40 $26.00
$1.08 $1.20
$3.85 $4.28
$4.39 $4.88
$4.48 $4.98
$8.35 $9.28
