DSTH01 Temperature & humidity sensor module si7005 sensor module
Designed by DORJI in China
Overview I2C host interface Temperature range: -40°C ~+85°C Temperature accuracy: ±0.5°C (typical) RH operating range: 0~100% RH accuracy: ±3% (typical) Wake up time: 10ms Integrated on-chip heater …
Read More…DSTH01 is a type of digital relative humidity and temperature sensor module which integrates temperature and humidity sensor elements, an analog-to-digital converter, signal processing, calibration data and an I2C host interface. Both the temperature and humidity sensors are factory-calibrated and the calibration data is stored in the on-chip non-volatile memory which ensures the DSTH01 modules are fully interchangeable and no recalibration or software changes are required.
Necessary components are integrated on the DSTH01 modules so users can get a quick start with the microcontroller with extra design. The sensor top is covered with silicon gel which can protect the sensor from the dust and other particles. The module works at 2.1~3.6V. It consumes about 240uA during RH conversion. and 1.5mA in normal work mode. The DSTH01 module offers an accurate and factory-calibrated solution for embedded applications ranging from HVAC/R system to consumer electronic products.
Enter your email address if you'd like to be notified when si7005Temperature & humidity sensor module DSTH01 can be shipped to you:
Product: (4.33)
Documentation: (2.67)
Shipping: (4.33)
Communication: (3.33)
Ian | Oct. 16, 2017
Andrew | March 18, 2016
Marco | Feb. 11, 2016
$9.98
$3.68
$8.98
$8.28
$4.28
$7.98
$26.00
