Connect to UART serial via USB. Additionally, read/control 8 digital ports, assignable independently as input or output.
Designed by GMD_Communications in United States of America
The GMD Communications' DIO8-MCP22 provides 8 digital I/O ports for your PC via USB, each selectable for Input or Output. Additionally, it provides connections for a 4 pin header to provide a TTL Vi…
Read More…The GMD Communications' DIO8-MCP22 provides 8 digital I/O ports for your PC via USB, each selectable for Input or Output. Additionally, it provides connections for a 4 pin header to provide a TTL Virtual COM port.
Very few Digital I/O solutions available are both inexpensive AND reliable. This little board achieves both. Quantity discounts available.
Powered by USB, the DIO8-MCP22 sports a mini-USB connection, screw terminal block connectors, pullup resistors, and a reset switch. Utilizing the Microchip MCP-2200, it functions as a USB HID device for I/O. Three mounting holes allow the use of standoffs for mounting/stacking. Multiple boards can be used on the same computer.
Enter your email address if you'd like to be notified when USB to UART w/8 selectable Digital I/O can be shipped to you:
1-9 | $16.95 |
10-24 | $15.95 |
25-49 | $14.95 |
50-99 | $13.95 |
100-1999 | $12.95 |
2000+ | $11.95 |
$16.99
