What is it? This adapter board converts the 6 pin std ICSP header into a breadboard friendly 6 pin plug Why did you make it? This Programming board is used to program the Neotiny.AT Microcontroller b…
Read More…This adapter board converts the 6 pin std ICSP header into a breadboard friendly 6 pin plug
This Programming board is used to program the Neotiny.AT Microcontroller board that will be available very soon.
This adapter not only programs the Neotiny.AT, but anything requiring an ICSP connection. The wiring on the breadboard end is up to you. Just a few jumper wires and you can start programming anything that needs that ICSP connection.
Batavia, IL, United States of America
