The NorCal 40B is the newest revision of the classic QRP transceiver - now, even better!
Sold By NM0S Electronics
The NorCal 40B is a compact and efficient 40-meter CW transceiver. No other QRP transceiver offers its combination of extremely low current drain, high performance, reliability, and ease of assembly.…
Read More…The NorCal 40B is a compact and efficient 40-meter CW transceiver. No other QRP transceiver offers its combination of extremely low current drain, high performance, reliability, and ease of assembly. These and other features have led many operators to choose the NorCal 40 radios, both for home station and lightweight field use.
Originally a project of the Northern California QRP Club, the NorCal 40B and its predecessors, the NorCal 40 and 40A have been field-tested by thousands of QRP enthusiasts world-wide.
With the NorCal 40B, the classic design has been further revised, making it easier than ever to build and operate. We've retained an essential ingredient that has made this rig so successful: the flexibility to adapt the ‘40B to your own needs. There’s plenty of extra front- and rear-panel and interior space.
Specifications
Numeric values given are typical; your results will be somewhat different. All measurements were made with a 13.8V supply and 50Ω load at the antenna.
General Size: 1.3" (H) x 4.6" (W) x 4.5" (D)
Power Requirements: 2.1 x 5.5mm coaxial plug, center positive.
Receive: 10 to 16 VDC; reverse-polarity protection 15 to 20 mA
Transmit: 400 mA - 500 mA at 3.0 watts output
VFO frequency: 2.085 MHz nominal
Tuning Range: Any 40 to 45 kHz segment of the 40m CW band (7.0-7.15MHz)
Drift: 100Hz total from cold start at 65°F
Dial calibration: Supplied by builder
Transmitter Max Output: 1.0 to 3.0 W.
PA efficiency: Up to 90%
Load Tolerance: 1.5:1 SWR, brief operation into high SWR No PA damage when transmitting into open antenna connection.
Antenna: 50Ω BNC
Transmit offset: 400-800 Hz, adjustable
T/R (transmit-receive) delay: 200 milliseconds
Receiver
Sensitivity: Better than 0.2uV for 10dB S+N/N
Min. discernible signal (MDS): -137dBm
Selectivity: 400Hz @ -6dB, 1.5kHz @ -30dB
Blocking dynamic range: 108dB
Two-tone dynamic range: 89dB
IF: 4.915MHz, 4-pole Cohn crystal filter
R.I.T. Range: +/- 2kHz at center of VFO tuning range
Audio output impedance: 8 Ώ or higher (headphones or speaker)
(3.5mm headphone plug required - see Operation)
Enter your email address if you'd like to be notified when NorCal 40B 7MHz CW QRP Transceiver Kit can be shipped to you:
Mount Vernon, IA, United States of America
9 Reviews | 397 Orders
$24.88
$38.88
$54.99
$169.00
