Nixie Tube Clock Kit with IN-12 Tubes, PV Electronics Quality. This is a kit, it needs to be soldered together!
Designed by PV Electronics in United KingdomNo shipping info available.
• Hobby Clock Kit of Parts to be soldered together • Hours and Minutes display on four IN-12 tubes • 0.71" / 18mm Digit Height • Ideal as a gift - either the kit or the completed clock • Ch…
Read More…• Hobby Clock Kit of Parts to be soldered together
• Choose from a range of colours for the tube backlighting
• Programmable seconds display at end of minute
• Plexiglass case available here
• 12 or 24 hour modes
• Uses a Quartz Crystal Oscillator as the timebase
• Programmable leading zero blanking
• Supercapacitor backup. Keeps time during short power outages
• Simple time setting using two buttons
• Programmable neon colon settings (Flashing AM/PM indication, illuminated AM/PM indication, flashing, on, off)
• Seconds can be reset to zero to precisely the set time
• Programmable night mode - blanked or dimmed display to save tubes or prevent sleep disturbance
• Separate modes for colon neon during night mode
• Standard, or scrollback display modes
• ‘Slot Machine’ Cathode poisoning prevention routine
• Not AC frequency dependent – works in all countries
• All user preferences stored to non-volatile memory
Enter your email address if you'd like to be notified when Nixie Tube Clock Kit with IN-12 Tubes can be shipped to you:
Pierre | Oct. 6, 2020
$10.49 $14.99
$180.00
$8.39 $11.99
