Power Supply for Solderless Breadboard which outputs 5V @3A.
Designed by _DrAlexander_ in SwitzerlandNo shipping info available.
Description This kit outputs 5V at a max. current of 3A to both breadboard rails. This makes it perfect for all the circuit prototyping where more power or only a 5V supply voltage is needed. The sma…
Read More…This kit outputs 5V at a max. current of 3A to both breadboard rails. This makes it perfect for all the circuit prototyping where more power or only a 5V supply voltage is needed.
The small form factor is designed to fit into most commonly used Breadboard power rails.
This Kit has been created for engineers, hackers and other technical people to simplify the circuit prototyping process and to always have a fitting USB power supply on hand.
Features
Output Options
Important Notes
I was getting frustrated with the fact that for every circuit i wanted to prototype or quickly build on a breadboard, i had to quite often waste time with building a power supply with the needed voltage first. The other common option of using a lab power supply i didn't like that much since it adds a lot of cabling and I quite often wanted to have multiple circuits running at the same time, but I don't have that many lab power supplies.
Another factor that made me create this board is the re-usability of it. I often built similar supply circuits with SMD adapters and a couple passive components, but it was not practical to take one supply circuit from one project to another, because it would have to be rewired anyways to take it from one breadboard to another.
Enter your email address if you'd like to be notified when Power Supply Rail USB-C Mini Kit for Breadboard can be shipped to you:
1-2 | $2.75 |
3-4 | $2.50 |
5+ | $2.25 |
$3.80
$5.75
$3.60
$2.75
$3.80
$5.75
$3.60
