Multi channel led driver Analog or PWM dimming up to 20kHz
Designed by ALab Technology in Spain
This is a three-channel step-down, up to 60 V / 4.5 A each channel LED driver. Can drive up to 15x hight power LEDs from 60v supply. The product will be shipped fully soldered. You can select the ou…
Read More…This is a three-channel step-down, up to 60 V / 4.5 A each channel LED driver. Can drive up to 15x hight power LEDs from 60v supply.
The product will be shipped fully soldered. You can select the output current of each channel.
Enter your email address if you'd like to be notified when 60v Step-down High Brightness LED Driver can be shipped to you:
Michel | Aug. 30, 2023
$75.00
$37.00
$38.00
$31.00
