MSP-EXP430F5529LP Breakout for Solderless Breadboards
Designed by AHN-Design in Canada
A breakout board for using the TI MSP-EXP430F5529LP, conveniently, with solderless breadboards. The breakout was originally designed as a prototyping solution to simplify life in an undergraduate mic…
Read More…A breakout board for using the TI MSP-EXP430F5529LP, conveniently, with solderless breadboards. The breakout was originally designed as a prototyping solution to simplify life in an undergraduate micro-controller course. It was inspired by similar designs for Arduino and Raspberry Pi but has been developed specifically for the MSP-EXP430F5529LP. It will actually work for ANY of the TI Launchpad series, however the silk-screening is specific to the MSP-EXP430F5529LP.
This breakout has the following features:
- Breaks-out all of the Launchpad pins, in port/bit order
- Breaks-out both 3.3V and 5.0V into the solderless breadboard supply rails. Rail voltage is selectable through jumpers
- Adds a wee bit of decoupling to the supply rails (0.1uF, if you want more simply add bigger ceramic caps)
- Supplied with all required components, however is provided UNASSEMBLED
- Could be hacked to be a screw terminal breakout as well
Note(s):
- Kit is supplied UNASSEMBLED with all required components
- Break-off header pins will be supplied in 40pin (or shorter) lengths and will have to be cut to size
- This kit was designed for educational purposes and should NOT be used in any mission-critical, high-reliance, or safety devices.
If you are an instructor, feel free to contact me about volume discounts, board-only options, or board/screening modifications (subject to quantity)
If your shipping destination does not appear, please contact me for shipping options
Enter your email address if you'd like to be notified when Breadboard Breakout for MSP-EXP430F5529LP can be shipped to you:
$5.25
$4.95
