Compact board for AC loads dimming
Designed by Late Night Works in Italy
This board is used to manipulate AC sine waves in order to drive and dim AC loads. FEATURES: User friendly: it requires only two pin for the interface (except for supplies and load connections). …
Read More…FEATURES:
Works both with 50Hz and 60Hz current in a range of 110-240V alternated and can handle loads up to 8A.
Optoisolation: input and output pin are optoisolated from high voltage side so the board can be wired safely to external components and devices.
Low voltage logic level (5V): it can be used in combination to most common microcontrollers and development board (as Arduino and Raspberry for example).
Available in three versions: "Assembled kit", complete with all components, "Assembled kit + screw terminal blocks" on TP1,TP2,TP3,TP4,TRIAC,ZCD,GND and +5V pins and "Only PCB". In the second version, bill of materials will be shipped with the board.
Please, read attached datasheet for more detailed informations, examples and so on.
SETTING UP:
When 5v supply, AC supply and the load are connected, the boards turns on and it's ready to work:
APPLICATIONS:
Modifying the output AC wave, is possible to regulate the power of the load in different ways, as for example:
Phase angle control:
Zero-crossing control:
DISCLAIMER
WARNING! The product involves AC mains voltages and thus, high voltages that could possibly kill you. Please don't buy it if you are not qualified for working in this zone or if you are not sure of what you are doing.
This board follow standards rules of design with high voltages but it has no certification of it and then, the author take no responsibility for any injury or death, resulting from your approach to the board. ( directly or indirectly)
I USUALLY SHIP IN MOST COMMON DESTINATION BUT IF YOUR COUNTRY IS NOT ON MY LIST, PLEASE CONTACT ME FOR FINDING THE BEST SOLUTION.
Enter your email address if you'd like to be notified when AC Phase control board can be shipped to you:
$24.99
$6.99
