This is an Atmel SAMD21 Breakout board with on board SD card connector you can program it with the Arduino IDE.
Designed by APtech in MaltaThis product is no longer available for sale.
What is it? An Atmel SAMD21 Breakout board with on board Micro SD card connector and loaded with the Arduino boot loader so you can program it using the Arduino IDE set on Arduino/Genuino Zero (Nativ…
Read More…An Atmel SAMD21 Breakout board with on board Micro SD card connector and loaded with the Arduino boot loader so you can program it using the Arduino IDE set on Arduino/Genuino Zero (Native USB Port).
I needed a good SAMD21 breakout board with a Micro SD card connecter, didn't like what was on the market with all the IoT stuff (I don't like IoT)
The on board Micro SD card connecter which works with the standard Arduino libraries, the SPI select pin for the SD card is pin10 and even though that pin is being used it is still broken out (Marked by a white circle), and all the pins including the SPI pins face downwards meaning you can easily make or design boards to stick this thing on. Check us out on Facebook
Warning the pins are 3.3v logic level only.
$120.00
$7.40
$330.00
$5.70
$1.00
