It's a linescan camera designed for machine vision for slow boards like the Arduino.
Designed by APtech in MaltaThis product is no longer available for sale.
$109.00
$109.00
$297.00
What is it? It's a linescan camera designed for machine vision for slow boards like the Arduino. Why did you make it? I needed something simple to learn machine vision and an Arduino doesn't have eno…
Read More…It's a linescan camera designed for machine vision for slow boards like the Arduino.
I needed something simple to learn machine vision and an Arduino doesn't have enough processing power for that kind of stuff, so i made a camera that has only 1x128 pixels.
The fact that it has just 1x128 pixels makes it very easy to learn machine vision and especially if you are using an Arduino.
Ground pin.
3v3 to 5v so it is good for Arduino DUE too.
Pixel output analog.
Pixel clock.
Defines the start of the pixel data-out sequence.
The camera is basically a breakout board for the ams TSL1401CL line sensor (Cad files available in documentation) pdf is available in this page's datasheet section.
The camera is simple to use with an Arduino and Processing code available in this page in (Sours Code), these codes will allow you to see what the camera is seeing on your computer and start you off on using it, the problem is that the Processing code is for Mac but you can make this work by changing the com port names however i haven't tried this, to connect it to your Arduino first you have to connect a variable resistor wired as voltage divider with it's output voltage to the Arduino A1 pin this will be your saturation adjuster (you will see more in the Arduino code ;) ) Than connect the GND pin to the Arduino ground pin. connect the the +5V pin the Arduino 5V pin or 3V3 pin if you are using a DUE. connect the AO pin to the Arduino A0 pin. connect the CLK pin to the Arduino 12 pin. connect the SI pin to the Arduino 13 pin. and your done.
Documentation: (4.67)
Shipping: (3.83)
Communication: (4.67)
Aasam | July 6, 2020
Shane | Feb. 18, 2019
Josef | April 11, 2016
Raul | Feb. 27, 2016
Ian | May 18, 2015
Hong | April 26, 2015
$120.00
$7.40
$330.00
$5.70
