Apollo MSR-1 is the smallest mmWave CO2 multi sensor for HomeAssistant. **Shipping early December**
Designed by Apollo Automation in United States of AmericaThis product is no longer available for sale.
$13.48
$29.99 $39.99
Currently ships in early December * Connects via wifi to ESPHome for easy Home Assistant integration. Bluetooth Tracker (ESP32-C3-Mini) - YAML Config Required Track Bluetooth devices in your house, …
Read More…Connects via wifi to ESPHome for easy Home Assistant integration.
Track Bluetooth devices in your house, letting you know which devices are closest to the sensor. You will need to know the MAC of the bluetooth devices you want to track - Find your phone if you left it in the office or the bedroom. - Know who just walked into the room. - Track a beacon attached to your dog's collar.
Recognizes even the subtlest movements. Great for instantly detecting someone entering a room, and keeping you notified while they are in there even with minimal movement. - Keep lights or fans on in a room until everyone has left.
Offers better, more accurate light readings by having a dedicated light sensor in an optimal location. Check the UV index or just the light level. - Decide whether to turn on the lights when motion is detected. - Find out if your pet left the lights on.
Provides accurate readings of temperature, humidity, and pressure. The pressure enhances the readings from the CO2 sensor. Note: The ESP32-C3 in constant WiFi connection generates significant heat; you might need to adjust the offset based on your setup and the temperature/humidity won't be as good as a dedicated sensor with less heat build up.
This optional add-on brings a CO2 sensor to the package, which comes pre-calibrated and ready to use. (This device does not meet the requirements for CO2 safety monitoring per the NBIC, NFPA, or IFC) - Get alerts to open a window or automate your HVAC fan to run when CO2 levels are high.
Uses color-coded alerts for various home scenarios. - Flash red if the garage door is open. - Flash green on trash night. - Flash blue when it's treat time for your pup.
Emits different beep patterns based on various alerts. - Beep on and off when the CO2 level is high. - Beep three times if motion is detected in the basement when it shouldn't be. - Beep once when an exterior door opens.
Exposed GPIO pin, 3v, 5v, ground, and I2C on back of board. Allowing you to solder in your own addition. - External temperature sensor
$32.20 $46.00
