IR Blaster is a WiFi enabled device that can be used to control almost any infrared device.
Designed by Automate Things in United KingdomThis product is no longer available for sale.
With over 10 Meters range, the IR Blaster allows you to control almost any infrared device and is compatible with Tasmota and ESPhome. If you are feeling ambitious then you can even use the IRremoteE…
Read More…With over 10 Meters range, the IR Blaster allows you to control almost any infrared device and is compatible with Tasmota and ESPhome. If you are feeling ambitious then you can even use the IRremoteESP8266 Library with Arduino!
The device can be easily integrated into home automation solutions such as Home Assistant. You can even place the device behind your TV and it should still be able to control it. The best part is that as you decide what Firmware to install on it there is no need for another Mobile App or a Cloud Subscription.
What you get:
1x Wemos D1 Mini
1x IR Blaster PCB
9x TSAL6400 IR LEDs
3x 2N2222A
3x 6R8 Resistors
Things you will need to provide:
Configuration
Please see the example configuration in the "Datasheet" link at the bottom.
Bicester, Oxfordshire, United Kingdom
Ships from United Kingdom.
2 Reviews | 40 Orders
$441.00
$48.88
