CAT control enables you to control your Kenwood TS480 transceiver's frequency and also to key CW
Designed by AX KITs in Slovenia
This CAT control enables you to control your Kenwood TS480 transceiver's frequency and also to key CW from a LOG SW, like N1MM. CAT was made because we wanted to have a simple and effective control o…
Read More…This CAT control enables you to control your Kenwood TS480 transceiver's frequency and also to key CW from a LOG SW, like N1MM.
CAT was made because we wanted to have a simple and effective control of frequency and to key CW on a transceiver from the PC. It features DB 9 female connector that connects to your Kenwood transicever and 3.5 mm plug, that connects to your Key socket on transceiver. That leaves Paddle socket free where you can connect your paddle for manual CW work when needed. CAT control was tested with popular N1MM and TR4W LOG SW.
CAT is asssembled on a very small PCB to fit into DB9 connector's enclosure. With this CAT you can control your transceiver from your PC or manually. It utilizes very good FTDI USB chip that is a standard for industry.
It connects to your PC via Mini USB cable (not included).
Enter your email address if you'd like to be notified when CAT for Kenwood TS480 can be shipped to you:
We ship all orders as registered parcel, therefore all our parcels are trackable.
