4x16A Relay Extension for DIN Rail mount which can be driven by almost any analog or digital signal
Designed by Beni_Skate in Austria
What is it? Relay Extension (for example for Smart Home applications) 4 outputs each can drive 16A High quality industrial grade relays (this is also the main reason for the high price) DIN rail mou…
Read More…On many Loxone smart home systems, analog outputs remain unused and it is only possible to get a relay extension with 12 outputs for around 500$. So I wanted to create a cheaper solution to have outputs which can switch 16A with the use of the analog output.
If you want to have only a PCB or only a case or so just contact me. Also if you need multiple pieces just contact me - as some parts are quite expensive I only have a few on stock, but I can reorder them within a few days.
Enter your email address if you'd like to be notified when Relay Extension 4x16A (for DIN Rail mounting) can be shipped to you:
Typically I do shipments every Tuesday (depending on when I get orders sometimes also Monday or Wednesday). I need to try to combine multiple shipments to not have to increase the shipping prices. In exchange I will try to ship everything as priority (also when Standard Letter is selected). If you need something urgent or want a special shipping method (for example DHL) please just write a message.
$78.00
$36.00
$75.00
