What is it? Optical Audio Output for Raspberry Pi (1A+/1B+/2B/3B/3B+/4B/Zero) (1A/1B could be connected with cables but it doesn't fit directly) Hardware can also be modified to an optical input or …
Read More…Most TVs can't forward DolbyDigital/DTS 5.1 streams from HDMI to the optical output or HDMI ARC. (They can only output 5.1 streams which are generated by the TV and 5.1 streams which come over HDMI are always converted to a 2.0 stream.)
So I wanted to have a optical output for my RaspberryPi media center (OpenElec/LibreElec) to get the 5.1 stream directly to my 5.1 surround system. (Buying a audio extractor which extracts the audio signal from HDMI would have been also a possibility but most of them cost more than 50USD and there are often problems with HDMI CEC if you use this.)
OpenElec/LibreElec:
If you want to try it with Raspbian or any other distro just search the internet - there are lots of tutorials available for the HifiBerry Digi or PiFy modules (which all use the same drivers).
Warning: Some distributions (for example OpenElec) have an old Kernel which has a Bug in the Pi3 Bluetooth driver and prevents all audio modules from working - in this case Bluetooth must be disabled with an additional overlay file or the Kernel must be upgraded (LibreElec for example already has a newer Kernel and this problem is fixed). This problem is only present on Pi3 and also the same with all other HifiBerry/PyFy modules.
Enter your email address if you'd like to be notified when tinyToslink - Raspberry Pi Optical Audio can be shipped to you:
Typically I do shipments every Tuesday (depending on when I get orders sometimes also Monday or Wednesday). I need to try to combine multiple shipments to not have to increase the shipping prices. In exchange I will try to ship everything as priority (also when Standard Letter is selected). If you need something urgent or want a special shipping method (for example DHL) please just write a message.
Product: (4.91)
Documentation: (4.16)
Shipping: (4.78)
Communication: (4.75)
Daniel | Oct. 1, 2023
Leopold | April 1, 2023
Felix | June 15, 2022
Maciej | May 13, 2022
Gordon | April 11, 2022
István | March 28, 2022
Saku | Sept. 6, 2021
Wenzel | June 11, 2021
Michal | May 3, 2021
Stavros | April 14, 2021
Julien | March 9, 2021
Ratrimoarivony | Jan. 5, 2021
Richard | Aug. 25, 2020
Jochem | Aug. 10, 2020
Paul | June 24, 2020
Miljenko | Feb. 17, 2020
Casey | Dec. 16, 2019
Gyorgy | Nov. 28, 2019
Angel | Nov. 25, 2019
Joe | Oct. 28, 2019
Ivan | May 2, 2019
Xavier | Jan. 9, 2019
Kerekes | Dec. 27, 2018
Jami | Sept. 12, 2018
Kjetil | Sept. 11, 2018
Daniel | Aug. 15, 2018
Jens | March 9, 2018
Richard | Jan. 5, 2018
Matti | Jan. 4, 2018
Jiri | Nov. 4, 2017
Pj | May 18, 2017
Fernando | April 21, 2017
$75.00
