EleLab_V2 - Low cost, modular electronics lab system - PowerFeed PCB
Designed by Binary-6 in Germany
EleLab_V2 The low cost, modular electronics lab system for hobbyists. Please check out the Github Repo for full details and building instructions! PowerFeed This is the main infeed to connect your po…
Read More…The low cost, modular electronics lab system for hobbyists.
This is the main infeed to connect your power supply to the backpanel bus and feed into the modules. It packs jacks to plug in your SFX supply, screw connectors for external fuses, and a breakout for the SFXs standby switch. Alternatively you could wire up your supplies directly to the spots marked as 24V, 12V and 5V respectively without using ATX connectors.
It is used to create modules like the ATX/SFX infeed.
It is available with or without the connectors.
Please check out My full store for the other PCBs or printed parts!
Enter your email address if you'd like to be notified when EleLab_v2 - PowerFeed PCB can be shipped to you:
$1.00
$134.99
$3.50
