Nordic nRF5340 BT5 Bluetooth Module Pre-Certified BQB/FCC/IC/CE/Telec/KC/SRRC/NCC LE Audio
The development kit deployed MDBT53V-1M module (nRF5340 Solution) Raytac’s MDBT53V & MDBT53V-P is a BT 5.2 stack (Bluetooth low energy or BLE) module designed based on Nordic nRF5340 SoC solution, wh…
Read More…The development kit deployed MDBT53V-1M module (nRF5340 Solution)
Raytac’s MDBT53V & MDBT53V-P is a BT 5.2 stack (Bluetooth low energy or BLE) module designed based on Nordic nRF5340 SoC solution, which incorporates: GPIO, SPI, UART, TWI, I2S, PDM, PWM, ADC, NFC and USB interfaces for connecting peripherals and sensors.
The compact size 7.8 x 12.4 x 1.85 (1.60)mm incorporates 25 GPIO, integrated various antenna types option (Chip Antenna, PCB antenna, u.FL connector) provides developers flexibility to meet most IoT Application Demanding, Connectivity Range Requirement, BOM Cost Saving, Designs Simplifying, and Time-TO-Market Efficiency.
Certification:
Antenna Option
About The Module:
Enter your email address if you'd like to be notified when nRF5340 Module (25GPIO) EvKit Board BT5.2 MDBT53V can be shipped to you:
Ships from Taiwan.
3 Reviews | 224 Orders
$19.98
$4.98
$9.98
