Programming or debugging a development board or Kit that uses 10-pin 1.27mm (0.05") pitch SWD programming connectors
The cable has 150mm length which is used for programming or debugging a development board or Kit that uses 10-pin 1.27mm (0.05") pitch SWD programming connectors. Applicable to connect with Nordic D…
Read More…The cable has 150mm length which is used for programming or debugging a development board or Kit that uses 10-pin 1.27mm (0.05") pitch SWD programming connectors.
Applicable to connect with Nordic DK board or Raytac's module demo board or other applicable development kit.
Enter your email address if you'd like to be notified when 10-pin 2x5 Socket-Socket 1.27mm IDC (SWD) Cable can be shipped to you:
Ships from Taiwan.
3 Reviews | 227 Orders
$1.70
$7.50
