Central(Master) + Peripheral(Slave) Bluetooth Long Range AT Command Bluetooth Module Demo Kit BT5.1 & BT5.0 FCC IC CE Pre-Certified
Raytac's Modules 100% Made In Taiwan; No worry about the Trade War Risk With China! Supports BT5.2 / BT5.1 /B5.0 Long Range Feature Supports 2 roles in 1, either Central/Master or Peripheral/Slave ro…
Supports BT5.2 / BT5.1 /B5.0 Long Range Feature Supports 2 roles in 1, either Central/Master or Peripheral/Slave role Supports USB / UART Interface
Bluetooth Certification: BT5.1 & BT5.0 Solution: Nordic nRF52833 Demo board deployed Raytac's Module: MDBT50Q-ATMS Safety Regulation Compliance: FCC (USA) / IC (Canada) / CE (EU) / Telec (Japan) / SRRC (China) / KC (Korea) / NCC (Taiwan) / RCM (ANZ) / WPC(India)
Development Board Dimension: (L) 6.7cm x (W) 3.9cm
User Guide and Module Specification can be found in Raytac's Website
Features:
Central / Master: - Hardware selecting of UART or USB interface
Enable/disable interface of UART hardware for saving power
Setting of device role as Central or Peripheral
Setting of scanned device name
Setting of scanned base UUID / service UUID / TX character / RX character
Setting of scanned RSSI threshold
Select data rate of 1 Mbps, 2 Mbps or 125 Kbps on-air
Select output power in 6 levels.
Select connection interval mode
Select UART baud rates / auto baud rates under USB mode
Select LDO or DC-to-DC power mode
Select external or internal RC 32.768KHz oscillator
System reset of software or hardware
Recover-to-default setting with hardware and software method
Set scanning/ idle time
Start or stop scanning
Set LED pattern indicating scanning, idle or connecting status
Enable/disable UART flow control
Power-down mode for power saving and GPIO wake-up
Support DLE / maximum MTU 247 bytes / data payload up to maximum 244 bytes
Print out scan list including RSSI, MAC address and device name
Support direct connection to the device with specific MAC address
Scan beacon company ID/UUID (support extended advertising beacon)
Enable/Disable beacon information printed out through from USB/UART interface
Peripheral / Slave: - Hardware selecting of UART or USB interface
Setting of advertising device name
Setting of base UUID / service UUID / TX character / RX character
Select UART baud rates / USB mode auto baud rates
Set advertising time
Setting of advertising interval
Start or stop advertising
Set LED pattern indicating advertising or connecting status
Set serial number and retrieve
Set or retrieve MAC Address
Retrieve ADC value for battery detection, delivering the information through battery
service
Enter your email address if you'd like to be notified when Central+Peripheral AT Command Module Demo Board can be shipped to you:
Ships from Taiwan.
3 Reviews | 227 Orders
$7.50
$2.95
