Nordic nRF52811 BT5 Bluetooth Module Pre-Certified BQB/FCC/IC/CE/Telec/KC/SRRC/NCC
Raytac's Modules 100% Made In Taiwan; No worry about the Trade War Risk With China! Raytac’s MDBT42Q-192KL & MDBT42Q-P192KL is a BT5.2 and BT4.2 stack (Bluetooth low energy or BLE) module designe…
Raytac’s MDBT42Q-192KL & MDBT42Q-P192KL is a BT5.2 and BT4.2 stack (Bluetooth low energy or BLE) module designed based on Nordic nRF52811 SoC solution, which incorporates: GPIO,SPI, UART, I2C, PWM and ADC interfaces for connecting peripherals and sensors.
Certification:
About The Module:
Compact size with (L) 13.8 x (W) 8.8 x (H) 2.2 mm.
Antenna Option
Features:
Multi-protocol 2.4GHz radio
‧192KB flash programmed memory and 24KB RAM
‧RSSI
‧Flexible and configurable 32 pin GPIO
‧1 x Hardware SPI master ; 1 x Hardware SPI slave
‧1 x two-wire master ; 1 x two-wire slave
‧1 x UART (CTS / RTS)
‧PDM for digital microphone
‧Quadrature demodulator
‧12-bit / 200KSPS ADC
‧Low cost external crystal 32MHz ± 40ppm for Bluetooth ; ± 50ppm for ANT Plus
‧Low power 32MHz crystal and RC oscillators
‧On-chip DC/DC buck converter
‧Timer counter
‧3x 32-bit
‧2 x 24-bit RTC
‧4-channel pulse width modulator (PWM) unit with EasyDMA
Recommend to have module firmware development according to Nordic S112 SoftDevice Nordic Semiconductor’s S112 v5.1 is a memory-optimized Bluetooth® 5 protocol stack for building high-performance Bluetooth Low Energy applications on the nRF52810 multi-protocol SoC. S112 occupies approx. 100kB of flash memory and thus enables more sophisticated applications that require fewer connections when in operation. S112 supports the following Bluetooth LE roles in concurrent operation:
Peripheral x 2; Broadcaster x 1; Observer x 1 S112 v5.1 is a highly featured, qualified Bluetooth 5 protocol stack that can significantly improve your application’s performance with its support for the following:
Bluetooth 5: 2Mbps datarate; Bluetooth 5: Channel Selection Algorithm #2; Configurable ATT MTU; LE Secure Connections; Link Layer Ping; Privacy 1.2
Enter your email address if you'd like to be notified when nRF52811 BT5.2 Module MDBT42Q (Chip/PCB Antenna) can be shipped to you:
Ships from Taiwan.
3 Reviews | 227 Orders
$9.90
