Nordic nRF52820 Module 18GPIO BT5.2 (Bluetooth/Zigbee/Thread/ANT+) FCC CE IC Telec MIC KC SRRC NCC RCM Chip & PCB Antenna
Raytac’s MDBT50-256R & MDBT50-P256R is a BT 5.0 & BT 5.1 stack (Bluetooth low energy or BLE) module designed based on Nordic nRF52820 SoC solution, which incorporates: GPIO, SPI, UART, I2C and USB in…
Read More…Raytac’s MDBT50-256R & MDBT50-P256R is a BT 5.0 & BT 5.1 stack (Bluetooth low energy or BLE) module designed based on Nordic nRF52820 SoC solution, which incorporates: GPIO, SPI, UART, I2C and USB interfaces for connecting peripherals and sensors.
Bluetooth Certification: BT5.2 & BT5.1 & BT5.0 Safety Regulation Compliance: FCC (USA) / IC (Canada) / CE (EU) / Telec (Japan) / SRRC (China) / KC (Korea) / NCC (Taiwan)
Antenna - Chip Antenna: Raytac P/N: MDBT50-256R - PCB Antenna: Raytac P/N: MDBT50Q-P256R
ARM Cortex –M4 32-bit processor, 64 MHz
Memory: 256KB flash / 32KB RAM
Supply: 1.7V – 5.5V
Flexible and configurable 18 GPIO
Operating Temp: -40°C to +105°C
Enter your email address if you'd like to be notified when nRF52820 BT5.2 Antenna Module Raytac MDBT50 can be shipped to you:
Ships from Taiwan.
3 Reviews | 227 Orders
$7.50
$19.98
$9.98
$5.50
