Nordic nRF52832 BT5 Bluetooth Module Pre-Certified BQB/FCC/IC/CE/Telec/SRRC/NCC
Raytac's Modules 100% Made In Taiwan; No worry about the Trade War Risk With China! Raytac’s MDBT42V & MDBT42V-P is a BT5.2 & BT4.2 stack (Bluetooth low energy or BLE) module designed based on No…
Raytac’s MDBT42V & MDBT42V-P is a BT5.2 & BT4.2 stack (Bluetooth low energy or BLE) module designed based on Nordic nRF52832 SoC solution, which incorporates: GPIO, SPI, UART, I2C, I2S, PWM and ADC interfaces for connecting peripherals and sensors.
Certification:
Regulation: FCC/IC/CE/Telec/SRRC/NCC
Antenna Option
Features: ‧Compact size with (L) 8.4 x (W) 6.4 x (H) 1.5 (1.75) mm
‧Multi-protocol 2.4GHz radio
‧RSSI
‧Dynamic on-air payload length up to 256 bytes ‧Flexible and configurable 20 pin GPIO
‧1 x UART (CTS / RTS)
‧PDM for digital microphone
‧I2S for audio
‧Quadrature demodulator
‧12-bit / 200KSPS ADC
‧On-chip DC/DC buck converter
‧Timer counter
‧5 x 32-bit
‧3 x 24-bit RTC
Enter your email address if you'd like to be notified when nRF52832 BT5.2 Module MDBT42V (Chip/PCB Antenna) can be shipped to you:
Ships from Taiwan.
3 Reviews | 227 Orders
$9.90
