Nordic nRF52833 Module 42 GPIO BT5.2 (Bluetooth/Zigbee/Thread/ANT+) FCC IC CE MIC Telec KC SRRC NCC RCM Pre-Certified Chip & PCB Antenna
Raytac's MDBT50Q module deploy Nordic nRF52833 is a Bluetooth 5 (BLE), Zigbee and Thread (802.15.4) modular solution and is an advanced multi-protocol SoM with an ARM® Cortex™-M4F CPU and featured bu…
Read More…Raytac's MDBT50Q module deploy Nordic nRF52833 is a Bluetooth 5 (BLE), Zigbee and Thread (802.15.4) modular solution and is an advanced multi-protocol SoM with an ARM® Cortex™-M4F CPU and featured built-in USB and 5.5V compatible DC/DC supply.
The compact size 10.5 x 15.5 x 2.2)mm incorporates 48 GPIO, integrated various antenna types option (Chip Antenna, PCB antenna, u.FL connector) provides developers flexibility to meet most IoT Application Demanding, Connectivity Range Requirement, BOM Cost Saving, Designs Simplifying, and Time-TO-Market Efficiency.
Certification:
Antenna - Chip Antenna: Raytac P/N: MDBT50Q-512K - PCB Antenna: Raytac P/N: MDBT50Q-P512K
About The Module
Enter your email address if you'd like to be notified when nRF52833 Modue BT5.2 Raytac MDBT50Q (42 GPIO) can be shipped to you:
1-599 | $6.30 |
600+ | $6.00 |
Ships from Taiwan.
3 Reviews | 227 Orders
$9.60
$6.30
$9.90
