Nordic nRF52840 BT5 (Bluetooth/Zigbee/Thread/ANT+) Mulitprotocol Pre-Certified Module
Raytac's MDBT50Q module deploy Nordic nRF52840 is a Bluetooth 5 (BLE), Zigbee and Thread (802.15.4) modular solution and is an advanced multi-protocol SoM with an ARM® Cortex™-M4F CPU and featured bu…
Read More…Raytac's MDBT50Q module deploy Nordic nRF52840 is a Bluetooth 5 (BLE), Zigbee and Thread (802.15.4) modular solution and is an advanced multi-protocol SoM with an ARM® Cortex™-M4F CPU and featured built-in USB and 5.5V compatible DC/DC supply.
The compact size 10.5 x 15.5 x 2.0 (2.2)mm incorporates 48 GPIO, integrated various antenna types option (Chip Antenna, PCB antenna, u.FL connector) provides developers flexibility to meet most IoT Application Demanding, Connectivity Range Requirement, BOM Cost Saving, Designs Simplifying, and Time-TO-Market Efficiency.
Certification:
Antenna Option
MDBT50Q & MDBT50Q-P Series Module Spec Sheet Download Link
https://www.raytac.com/download/index.php?index_id=43
About The Module:
Enter your email address if you'd like to be notified when nRF52840 BT5.2 Antenna Module Raytac MDBT50Q can be shipped to you:
Bohdan | May 24, 2021
Ships from Taiwan.
3 Reviews | 227 Orders
$6.30
$6.30
$9.90
