Nordic nRF5340 BT5.2 (Bluetooth/Zigbee/Thread/ANT+) LE Audio Mulitprotocol Pre-Certified Module
Raytac’s MDBT53 & MDBT53-P is a BT 5.2 stack (Bluetooth low energy or BLE) module designed based on Nordic nRF5340 SoC solution, which incorporates: GPIO, SPI, UART, TWI, I2S, PDM, PWM, ADC, NFC and …
Read More…Raytac’s MDBT53 & MDBT53-P is a BT 5.2 stack (Bluetooth low energy or BLE) module designed based on Nordic nRF5340 SoC solution, which incorporates: GPIO, SPI, UART, TWI, I2S, PDM, PWM, ADC, NFC and USB interfaces for connecting peripherals and sensors.
Part No. MDBT53-1M / Chip Antenna / 9.3 x 14.3 x 1.85mm MDBT53-P1M / PCB Antenna / 9.3 x 14.3 x 1.6mm
Enter your email address if you'd like to be notified when nRF5340 BT5.2 Antenna Module Raytac MDBT53 can be shipped to you:
Ships from Taiwan.
3 Reviews | 227 Orders
$19.98
$5.50
$4.98
