Nordic nRF5340 BT5.2 (Bluetooth/Zigbee/Thread/ANT+) LE Audio Mulitprotocol Pre-Certified Module u.FL Connector for External Antenna
Raytac’s MDBT53-U is a BT 5.2 stack (Bluetooth low energy or BLE) module designed based on Nordic nRF5340 SoC solution, which incorporates: GPIO, SPI, UART, TWI, I2S, PDM, PWM, ADC, NFC and USB inter…
Read More…Raytac’s MDBT53-U is a BT 5.2 stack (Bluetooth low energy or BLE) module designed based on Nordic nRF5340 SoC solution, which incorporates: GPIO, SPI, UART, TWI, I2S, PDM, PWM, ADC, NFC and USB interfaces for connecting peripherals and sensors. What is it?
Bluetooth Low Energy Module, Mulitprotocol Bluetooth, Zigbee,Thread (IEEE 802.15.4), ANT+ What makes it special?
Size Compact, 48GPIO, 1.7~5.5V input voltage, Operation Temperature: -40°C~105°C and BT5.2/FCC/IC/CE/Telec/KC/SRRC/NCC Pre-Certified
Enter your email address if you'd like to be notified when nRF5340 BT5.2 u.FL Con. Module Raytac MDBT53-U can be shipped to you:
Ships from Taiwan.
3 Reviews | 227 Orders
$9.98
