Learn to solder, and learn a little bit about electronics as well
Designed by Bluino Electronics in IndonesiaThis seller is taking a break. Sign up below to get an email when they're back!
What you get - 1 x PCB (Red is manufactured in the China by PCBWAY). - 2 x Transistor NPN BC547 - 2 x Green LED 5mm - 2 x Capacitor 100uF/16V - 2 x Resistor 10K ohm 1/4W - 2 x Resistor 100 ohm 1/4W -…
Read More…What you get - 1 x PCB (Red is manufactured in the China by PCBWAY). - 2 x Transistor NPN BC547 - 2 x Green LED 5mm - 2 x Capacitor 100uF/16V - 2 x Resistor 10K ohm 1/4W - 2 x Resistor 100 ohm 1/4W - 1 x Switch SPDT SS12D00G3 - 1 x Baterai Cell 3V CR2032 - 1 x CR2032 Battery holder.
Note: Robadge kit hasn't been soldered yet - 1 x Pin back
Enter your email address if you'd like to be notified when DIY Robadge LED Blink Badge Kit Learn To Solder can be shipped to you:
$17.00
$89.00
$24.99
$17.00
$28.95
$28.99
$23.99
$9.49 $9.99
$8.54 $8.99
$7.50
$9.75
