Simple, small 5V regulator for your breadboard. Just add wall wart with Arduino-size 2.1mm DC jack.
If you're sick of hunting around for a power source for your breadboard projects and want a simple, small, and convenient power module, well, here's the solution. After you solder in the pin headers,…
Read More…If you're sick of hunting around for a power source for your breadboard projects and want a simple, small, and convenient power module, well, here's the solution.
After you solder in the pin headers, plug in a power supply into the 2.1mm jack, it's time to start making stuff while your pals are still trying to figure out how to wire that 9V battery to a crappy 7805.
Option | Part/Datasheet | Current | Vin | Vdo | Protection? |
5V Standard | STM LF50 pdf | 0.5A | 6-16V | 200-700mV | Current, Voltage, Temp |
5V High Current | STM LD29150 pdf | 1.5A | 6-14V | 100-700mV | Current, Voltage, Temp |
3.3V Low Voltage | NCP 5500 pdf | 0.5A | 4-16V | 5-700mV | Current, Voltage, Temp, Reverse |
5V Low Voltage | NCP 5500 pdf | 0.5A | 5.7-16V | 5-700mV | Current, Voltage, Temp, Reverse |
Open Source Hardware repository
Designed and assembled in the United States of America.
Enter your email address if you'd like to be notified when 5V breadboard power supply can be shipped to you:
57 Reviews | 878 Orders
$26.00
$54.99
$29.95
$34.95
