BMP585 High-Accuracy Pressure Sensor, detect altitude changes with centimeter accuracy, liquid-proof, tiny 3.3v board with I2C interface
Designed by aiperf in United States of America
What is it? Sensor board for the extremely accurate Bosch BMP585 Air Pressure and Temperature sensor. The highly accurate BMP585 is carefree and ready for any adventure. With its exceptional precisio…
Read More…Sensor board for the extremely accurate Bosch BMP585 Air Pressure and Temperature sensor.
The highly accurate BMP585 is carefree and ready for any adventure. With its exceptional precision, the BMP585 can detect height changes of just a few centimeters. It can even track movements such as individual push-ups. It is extremely rugged, thanks to the BMP585's gel-filled cavity that protects it against water, other liquids, and chemicals.
The sensor can be used for applications such as height measurement, water-level detection, and navigation, with a maximum absolute accuracy of ±0.50 hPa and a temperature coefficient offset (TCO) of ±0.005 hPa/K. The new BMP585 sensor, with its small footprint, offers outstanding design flexibility, providing a single-package solution that is easy to integrate into other devices.
Easily connect the BMP585 via I2C. The operating voltage ranges between 1.2v and 3.6v, typically 1.8v to 3.3v. This sensor is not designed to use more than 3.6v and we did not add a level shifter on the sensor board to keep it small and not add cost.
This is the latest Bosch Sensor that I couldn’t find available anywhere else.
Advantages:
The pin header comes unsoldered so you are free to connect directly to cables instead.
It has no onboard level-shifter to 5V in order to be small and cheap, so only power it with 3.3v.
Sports (centimeter accuracy)
Nautical
Home
Remote vehicle uses
Other Pressure Sensor uses
Enter your email address if you'd like to be notified when BMP585 High-Accuracy Pressure Sensor 3.3v Board can be shipped to you:
All sensors shipped in 6x9 inch Biodegradable Compostable Shipping Bags! Made of PBAT and modified corn starch in accordance with ASTM 6400, EN13432, BPI, and OK COMPOST HOME.
Rates to United States of America: Packages are shipped with United States Postal Service's Ground Advantage. There is tracking and $100 carrier liability. Estimated delivery up to 5 days not including Sundays, non-continental up to 26 days Cost $6.31, each additional item $1
International rates: Packages are shipped with UPS Worldwide Expedited. There is tracking and $100 carrier liability. Estimated delivery is in 2 to 5 business days. Cost $25, each additional item $1
$35.95
$29.95
$35.95
$4.50
