Seeed Xiao to CAN + FET adapter node
Designed by Burke Science in United States of AmericaThis seller is taking a break until Sept. 30, 2026. Sign up below to get an email when they're back!
What is it? Powered by either USB or 12V (hard switchable), this is a CAN node adapter to mate your favorite Xiao device onto. Has two onboard N-Channel FETs hanging off the 12V line. Designed to h…
Read More…Powered by either USB or 12V (hard switchable), this is a CAN node adapter to mate your favorite Xiao device onto. Has two onboard N-Channel FETs hanging off the 12V line. Designed to handle a total of 12V 5A giving you some fun options.
MCUs tested against:
Does not ship with MCU!
I needed a tidy way to control IoT and 12V devices, namely lighting and fans off a big battery. It turns out that wireless communication is less romantic when you have to run a power cable anyway, so why not get some rock solid reliable CAN comms while we're at it?
Usually to do this a lot of bare wiring and fiddly pieces are required. That bugged me, so I made this to clean up that mess and consequently fit your CAN nodes into a smaller area.
The equipment is pretty straightforward:
D2 & D3D0 positionBe sure to switch 12V off when USB is plugged in! CAN transceiver is active regardless of power source, and 12V will still go to the FETs.
Power arrives over GX12's pins. A separate power distribution board is available, or you can wire up the GX12 yourself.
Addressed as TRIG1 (D7 or D8, jumper selectable) and TRIG2 (D6)
In actuality there are 3x AO3400. I doubled up TRIG1 for extra power handling. Casual testing indicates it's plenty happy supplying 30W.
Be advised TRIG1 has a pulldown resistor on the gate, but TRIG2 is floating.
NOTE at this time part is only available fully assembled
Base option is the kit. Partially assembled. Includes components needed for you to populate it yourself. Be advised there are some SMDs. Kit contents:
Kit leaves my apartment with Mini360 set to 3.6V. Stay within 5% of that and double check before soldering! After diode drop that lands at about 3.3V.
I'll be experimenting with hot gluing the pot into place at some point, but for now it's adjustable.
Pinout descriptions for GX12 is supplied as a PDF with purchase
Coming soon is a ultra simple power distribution board to go with this guy. 4x GX12 + 12V terminal input. I have 'em now, just putting them through testing before listing them.
What will you build? A motorized nerf gun cat tracking network? Your own smart LED lighting strips? Cabinet lighting which alerts you when batteries are low or someone steals your socks? So many possibilities!
Feedback on v2 is welcome. There are two reserved pins left on the 6 pin GX12. Do not use them, they are planned to carry extra power in future designs!
I use J1939 for all my own CAN stuff. If you're interested in that, test code is available here
ESP32 CAN (esp-idf twai) bringup is pretty intuitive. See official documentation
No official firmware comes with this device. Bring up is easy with Arduino
Enter your email address if you'd like to be notified when CAN FET Xiao adapter can be shipped to you:
$64.00
$44.00
