All-passive power distribution
Designed by Burke Science in United States of America
What is it? Simple power distribution system with 4x GX12 and aux 12V + HV ports Also has 2.54mm pitch breakout for CAN H, CAN L and CAN termination as well as a 5mm header for 12V Why did you make i…
Read More…Simple power distribution system with 4x GX12 and aux 12V + HV ports
Running bare wire around to power things was getting annoying! This eases usage and powering of https://www.tindie.com/products/burke-science/can-fet-xiao-adapter/
Part of a whole tidier-than-average process. For use with CAN FET Xiao adapter
Extremely simple board, all passive components. I get a lot of utility out of the power distribution and CAN 2.54mm header
Be advised 2nd 5mm power header is reserved. Only use the 1st 12V power header.
Raw board with no components. Useful if you won't want the LED or 5mm headers on there.
Kit content excludes Molex headers, as Molex usage is still experimental.
Includes everything in kit plus assembled Molex headers also.
You'll receive round GX12 connectors vs the square pictured. The square ones are cool, but block functionality. If you really want the square ones, message me and we'll see what we can do :)
Enter your email address if you'd like to be notified when CAN Power can be shipped to you:
