This is a PCB board to replace the 3DS xl charging port so you can use USB-C cables to charge (usb-c to usb-c charging)
UPDATED: The jig is now a much simpler slip on resin jig. This is a PCB USB-C charging port to replace the original charging port on the 3DS-XL, this port works with USB-C to USB-C cable charging so …
Read More…UPDATED: The jig is now a much simpler slip on resin jig.
This is a PCB USB-C charging port to replace the original charging port on the 3DS-XL, this port works with USB-C to USB-C cable charging so you don't need to worry about having a USB to USB-C cable.
The Installation jig allows you to solder down the castellated holes while holding the PCB in perfect alignment.
While I've tested the jig on a few 3DS XL boards I can't guarantee a perfect fit so some sanding may be required, due to the snipping require I considered the jig a one-use item. In testing I get ~5.1 V and .75A while charging. I do not preserve the old gold contacts of the 3DS XL.
Here is my installation process (refer to pictures):
Sanding/fitting and final steps: 1. Take some flush cutters and snip away at the plastic 'gate' of the old charging port. 2. Put the bezel on the USB-C port and reassemble the 3DSXL 3 (optional). keep cutting down the plastic if you find it's not fitting to your liking, not much needs to be done so do be careful.
REQUIRED BUT NOT INCLUDED TOOLS: 1. A soldering Iron 2. Flux 3. Solder 4. Screwdrivers 5. Multimeter
(highly) RECOMMENDED BUT NOT INCLUDED TOOL: 1. Hot air station 2. Hot plate
INCLUDED: 1. USB-C PCB board fully assembled 2. 3D Printed Installation Jig 3. 3D Printed bezel (white and black)
NOTE: Demonstration video is of the 3DS but the process is the same for the 3DS XL.
Enter your email address if you'd like to be notified when 3DS XL USB-C mod kit w/ snapjig+bezel can be shipped to you:
