This is a PCB board to replace the 3DS xl charging port so you can use USB-C cables to charge (usb-c to usb-c charging)
UPDATED: The jig is now a much simpler slip on resin jig. This is a PCB USB-C charging port to replace the original charging port on the 3DS-XL, this port works with USB-C to USB-C cable charging so …
Read More…UPDATED: The jig is now a much simpler slip on resin jig.
This is a PCB USB-C charging port to replace the original charging port on the 3DS-XL, this port works with USB-C to USB-C cable charging so you don't need to worry about having a USB to USB-C cable.
The Installation jig allows you to solder down the castellated holes while holding the PCB in perfect alignment.
While I've tested the jig on a few 3DS XL boards I can't guarantee a perfect fit so some sanding may be required, due to the snipping require I considered the jig a one-use item. In testing I get ~5.1 V and .75A while charging. I do not preserve the old gold contacts of the 3DS XL.
Here is my installation process (refer to pictures):
Sanding/fitting and final steps: 1. Take some flush cutters and snip away at the plastic 'gate' of the old charging port. 2. Put the bezel on the USB-C port and reassemble the 3DSXL 3 (optional). keep cutting down the plastic if you find it's not fitting to your liking, not much needs to be done so do be careful.
REQUIRED BUT NOT INCLUDED TOOLS: 1. A soldering Iron 2. Flux 3. Solder 4. Screwdrivers 5. Multimeter
(highly) RECOMMENDED BUT NOT INCLUDED TOOL: 1. Hot air station 2. Hot plate
INCLUDED: 1. USB-C PCB board fully assembled 2. 3D Printed Installation Jig 3. 3D Printed bezel (white and black)
NOTE: Demonstration video is of the 3DS but the process is the same for the 3DS XL.
Enter your email address if you'd like to be notified when Nintendo 3DS XL USB-C mod kit w/ snapjig+bezel can be shipped to you:
