Arduino Learning Shield will help you starting understanding all of the Arduino world. Covering from the most basic steps to advance ones.
Designed by Custom Made Electronics in NetherlandsNo shipping info available.
What is it? Arduino is probably the world most famous development board. With hundred of expansion shields allowing you to create thousands of projects. But where to start? For this, the Arduino Lear…
Read More…Arduino is probably the world most famous development board. With hundred of expansion shields allowing you to create thousands of projects.
For this, the Arduino Learning Shield will help you starting understanding all of the Arduino world. Covering from the most basic steps to advance ones like:
The Arduino Learning Shield contains: 1x Nokia LCD 1x Photo-resistor 1x Buzzer 1x 10K Potenciometer 1x DTH11 Temperature and Humidity sensor 1x RGB Led 3x Led´s 3x Pushbuttons 6x Expansion pin headers (for servos, sensors, I/O´s, etc...)
The board is fully compatible with the Arduino Uno R3 design or similar. Comes fully assembled no solder necessary, just connect to your Arduino Uno board upload the code and test in the real world. Making it perfect for a absolute beginners.
The board pinout and example codes can be found in here. (More examples will be placed)
Just download the code to you Arduino IDE, upload it and test it.
Custom Made Electronics - Build by a Maker to Makers
Note: Arduino UNO in the fotos is NOT included.
Enter your email address if you'd like to be notified when Arduino Learning Shield can be shipped to you:
