Proto Terminal Shield
Designed by Custom Made Electronics in NetherlandsNo shipping info available.
The Proto Terminal Shield gives you a better platform to make your Arduino projects in a quick and more robust way. All major Arduino pins are connected to 24 to 18 AWG terminal blocks allowing you …
Read More…The Proto Terminal Shield gives you a better platform to make your Arduino projects in a quick and more robust way. All major Arduino pins are connected to 24 to 18 AWG terminal blocks allowing you to connect external wires without the need of soldering.
The large prototyping area and the additional terminal blocks allows you to create and test your projects, giving you the extra pins and space, that do not exist in other similar products.
Using the Proto Terminal Shield will save you time debugging a bad pin connection or a loose wire.
Enter your email address if you'd like to be notified when Arduino Proto Terminal Shield can be shipped to you:
$100.00
$110.00
$285.00
