Airsoft/Paintaball / Laser Tag bomb prop
Designed by Custom Made Electronics in Netherlands
BombOne is a PCA board that allows you to create your own DIY prop device. It can be used for Airsoft, Paintball, Laser Tag, Escape Rooms, or as a simple timer. The system includes: 4 Game types…
Read More…BombOne is a PCA board that allows you to create your own DIY prop device.
System can be reprogrammed using Arduino IDE and an FTDI cable or simple replace the microcontroller (ATMEGA328P). The pinout of the board is provided in the instruction manual.
For more info, check out the video link.
Power requirements
Battery - 6Vdc to 24Vdc.
Dimensions: 90mm X 70mm
Note: This is an application example
Note: This is an application example build by a customer using BombOne
This is a prop for being used in Airsoft, Paintball games, Laser Tag or like a simple alarm clock.
We take no responsibility for the misuse of this device. Do not flash this product in front of security officers or pranks your colleagues and friends in order to avoid problems.
Video from Bomb One V2.2
Enter your email address if you'd like to be notified when BombONE Prop Bomb can be shipped to you:
$100.00
$285.00
$33.24 $34.99
$33.24 $34.99
$74.99
