Large prototype area, Arduino Uno R3 layout, Arduino Nano pinout with terminal block connections in all pins.
Designed by Custom Made Electronics in NetherlandsNo shipping info available.
Proto Nano Terminal Shield Give your project a new and better platform when using the Arduino Nano Board. The Proto Nano Terminal Shield allows wire-to-board connections, a large prototyping area, an…
Read More…Give your project a new and better platform when using the Arduino Nano Board. The Proto Nano Terminal Shield allows wire-to-board connections, a large prototyping area, an onboard 3.3V regulator and compatible Arduino Uno R3 pinout.
All Arduino Nano pins are connected to 24 to 18 AWG terminal blocks allowing you to connect external wires without the need of soldering. Extra terminal blocks give you extra power connections for faster and easier prototyping.
All SMD/SMT components and extra voltage regulator circuitry comes preassembled.
Features
Includes
The large prototyping area and the additional terminal blocks allows you to create and test your projects, giving you the extra pins and space, that do not exist in other similar products. Using the Nano Proto Terminal Shield will save you time debugging a bad pin connection or a loose wire.
Custom Made Electronics - Build by a Maker to Makers
Enter your email address if you'd like to be notified when Proto Nano Terminal Shield can be shipped to you:
$100.00
$110.00
$285.00
$4.95
$4.95
$17.70
