80mm OD, 47mm ID LED camera ring. 900 Lumens. Wide 10-28V input range. 5W max.
Designed by Zirconia3 Engineering in Australia
What is it? This is a 900 Lumen, fixed intensity, 16 LED camera ring light. It is designed to fit around a camera and provide bright and even lighting. LED ring comes pre-assembled, only connection t…
Read More…This is a 900 Lumen, fixed intensity, 16 LED camera ring light. It is designed to fit around a camera and provide bright and even lighting. LED ring comes pre-assembled, only connection to a power supply needs to be soldered.
The 16 LED Camera ring is designed to have a wide input range and be very efficient. The design uses a switch-mode supply so it will use a constant 5 Watts across the 10 to 28 Volt supply range. Due to the design the light out put will not flicker so the ring light will work with video.
All the photos were taken using the ring light.
Enter your email address if you'd like to be notified when 16 LED Camera Ring - 80mm can be shipped to you:
