develop and explore your CAN/ LIN bus with ESP32 s3 based caniot tools
Designed by CANIOT in Morocco
Caniot tool is a Multi-platform simulation, analysis and test environment for development and test of CAN/LIN bus systems. Simplicity is the highest principle when setting up, operating and expanding…
Read More…Caniot tool is a Multi-platform simulation, analysis and test environment for development and test of CAN/LIN bus systems. Simplicity is the highest principle when setting up, operating and expanding the system. The main advantages:
• User friendly lvgl GUI to control the caniotBox.
• C library allows the user to write programs for individual applications.
• Simulates messages and signals of missing control units from databases (arxml file,CAN dbc file, LIN ldf File).
• intuitive Caniot application for analysis: user panels, signal plots, dashboards, trace window.
• DBC/LDF decode data to physical values and plot
• Support ISO-TP 15765-2 and UDS ISO 14229.
• CaniotBox has simple logger which writes everything from CAN/LIN bus to csv file on a SD card (8-32GB).
• stream real-time data via USB or TCP Connection on your PC.
• stream real-time data to your own MQTT Server.
• CaniotBox update notification.
CaniotBox Specifications:
• Controller: ESP32 S3 with 240 MHz
• Flash: 16MB Serial Flash Memory
• RAM: 8MB Serial RAM Memory
• 1 CAN0 channels up to 1 Mbit/s
• 1 CAN1 FD channel up to 8 Mbit/s
• Supports both 11-bit (CAN 2.0A) and 29-bit (CAN 2.0B active) identifi-ers High-speed CAN connection (compliant with ISO 11898-2).
• 1 LIN channel up to 20 Baud.
• 1 K-LINE channel up to 150 Baud.
• 2.4 GHz proprietary protocol.
• internal antenna with max gain of 3dBi.
• Power supplied through 5V USB or external 5V to 40V input dsub 1.
• development tools Available for Windows, Linux and macOS.
• aluminum case.
Enter your email address if you'd like to be notified when CAN/LIN Bus caniot tools can be shipped to you:
