Customized filter 710-0.5, 8 OD Ultra Narrow Bandpass Filter with customized size (certified)
Sold By PolypickerThis product is no longer available for sale.
Ultra-narrowband optical interference filter with a 710 nm center wavelength (CWL), a 0.5 nm full-width at half-maximum (FWHM), and wide-range OD6 out-of-band blocking from 390 nm to 1000 nm. This is…
Read More…Ultra-narrowband optical interference filter with a 710 nm center wavelength (CWL), a 0.5 nm full-width at half-maximum (FWHM), and wide-range OD6 out-of-band blocking from 390 nm to 1000 nm. This is a multi-cavity filter with exceptionally steep edges, a flat top, and transmission that is greater than 90% at 710 nm. This ultra-narrowband filter is coated on a 2 mm thick Borofloat® substrate. This ultra-narrow bandpass filters have the highest transmission and narrowest bandwidths currently available. And because they are hard-coated using our innovative SIRRUS plasma deposition process, all of our optical filters are highly durable and resistant to laser damage.
SPECIFICATIONS
Angle of Incidence
0 Degrees
Filter Design
Multi-Cavity
FWHM
< 0.25 nm
Center Wavelength
532 nm Nominal
† Transmission Band(s)
532 nm > 90% T Absolute
Blocking Level
OD6
Dimensions
5.0 mm x 5.0 mm
Substrate Type
Borofloat®
Filter Thickness
2.0 mm
Assembly Type
Anodized Aluminum Ring
Assembly Thickness
3.5 mm
$54.00
$48.00
$54.00
$51.00
