Customized shortpass 950 nm filter 8 OD with customized 5 x 5 mm size (certified)
Sold By PolypickerThis product is no longer available for sale.
Shortpass optical interference filter with a 950 nm cut off wavelength (CWL), and wide-range OD6 out-of-band blocking from 1000 nm to 1900 nm. This is a multi-cavity filter with exceptionally steep …
Read More…Shortpass optical interference filter with a 950 nm cut off wavelength (CWL), and wide-range OD6 out-of-band blocking from 1000 nm to 1900 nm. This is a multi-cavity filter with exceptionally steep edges, a flat top, and shortpass transmission that is greater than 90%. This ultra-narrowband filter is coated on a 2 mm thick Borofloat® substrate.
Prajnesh | Aug. 4, 2021
$33.00
$54.00
$51.00
